Old 09-14-2013, 04:04 AM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by eschaider View Post
You guys are making this a whole lot harder than it really is. Jerry is giving you the short way home. Look at a cam chart card. TDC firing is a country mile from the INT closing or the EX opening ramps!
Ed
Simply another way, if the exhaust is opening- adjust inlet valve lash; inlet closing - adjust exhaust valve lash. Also quoted in the Comp Cam videos.
There are many ways, but TDC firing and adjust all valves for that cylinder is the easiest for beginners. Do each each cylinder in firing sequence. Too bad if you don't have a degreed balancer. That's when EOIC works.
View here: COMP Cams How to Set a Valve Lash - YouTube
Gary
