Old 09-14-2013, 05:24 AM
cobra 53's Avatar
cobra 53 cobra 53 is offline
Cobra Make, Engine: NAF 289 Blue/White strips
Default Broken valve spring
Since a longer time an "irregular clear TICK tone apears on the driver`s side valve train bank, next to the distributor like cylinder 5 or 6, sometimes noticed in the sidepipe.
This morning I`ve got time to go through them to search for the problem.
Result: I find the outside spring in cylinder 6 broken. The inside spring and damper are ok.
Next problem: Which spring do I choose as replacement? No number or ident. signs can be found at the broken spring.
Spring measures: OD 1.540", Length 2.470", Length in engine with closed valve 1.850"
SBF 302, FMS J 302 Alu heads, Comp CAM 31-760-8/288R valve lift 0.586"
Regarding the recomanded springs mentioned by Comp Camp, not a single measure of the installed springs corresponds.
Some proposals are welcome.
Rico
Rico, NAF 289
