Old 09-14-2013, 05:32 PM
PaulProe's Avatar
PaulProe PaulProe is offline
Cobra Make, Engine: Hurricane - FE
Default Patience
The curvature of the bowden cable will cause the knob to twist. You can loosen the connection at the air valve and then twist the knob in the direction you need, then retighten the connection. You may have to "over-correct" a little bit to compensate for the twist that is induced by the cables curve.
Paul
www.65shlb.com
www.prdcrrct.com
