  #21 (permalink)
Old 09-15-2013, 12:20 AM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by CHANMADD View Post
Hey Gaz..........I believe that the cam goes at half speed to the crank......that way if you rotate the crank 180.......then the cam will turn 360...........putting the lobe opposite to where it was..........its not to difficult to visualize......
I see what you meant to say:
"Hey Gaz..........I believe that the cam goes at half speed to the crank......that way if you rotate the crank 360.......then the cam will turn 180...........putting the lobe opposite to where it was..........its not to difficult to visualize......
Just a little dyslexia.
Gary
