Thread: shock advise
Old 09-17-2013, 07:57 PM
Pills's Avatar
Pills Pills is offline
Cobra Make, Engine: RAM, 5.0L with ST10 4 spd
The spares I have are original QA1 springs that did not fit the front due to their OD being too big. They should fit the rear ok but the rating may be too high, if you have a twin setup on each side.
I will check for you tonight when I get home from work. From memory one set is 400lb and the other less.
