Old 09-18-2013, 03:01 PM
David Hodgson's Avatar
David Hodgson David Hodgson is offline
Seven, have you got a rear bar yet? if not, I took some measurements off my bar last night. This was originally a DAX bar, not sure if they are all made the same.
Mouning hole centres are 790mm x 58mm
Mounting tube on bar 13mm I.D
Main bar pipe 25mm O.D
Upper mounting tube
centre from top of bar 35mm
So you would drill your top holes 35 mm below the highest point of your bar, and two more 58mm lower and 790 mm apart.
Holes should be large enough for the mounting bar and body grommets.
Hope that makes sense.
SLIPRY
