  #26 (permalink)
Old 09-19-2013, 06:44 AM
damage's Avatar
damage damage is offline
Cobra Make, Engine: Kirkham 427SC 482 Cammer
Originally Posted by spookypt View Post
I recently was pulled over by DOT for a random scales check and got talking to the officer about various things.. He was telling me about how many cars towing loaded car trailers aren't legal and they were doing a lot more random pull overs and fines with the scales...
While I was within my tolerances (F250 and enclosed alloy trailer) he mentioned many of the modern cars promoted with towing capacities etc of 3500kgs are towing overweight and illegally and are open to prosecution as there GCM exceeds the vehicle spec.
I was even more surprised that when I mentioned I was going to upgrade to an F350 that he said "make sure you get your license upgraded too!" As it has an GVM over 4500kg so I have to get a light truck license!!!
A light vehicle license in QLD (I think all states) is for over 4500kg GROSS VEHICLE MASS. It does NOT take trailer weight into consideration. Provided the towing vehicle has a GVM of under 4500kg and the trailer is below the maximum tow rating it is legal.
However..
Just because the GVM is 3500kg and the tow rating is 3500kg does not mean the combination can be 7000kg. You MUST ensure the GCM, Gross Combined Mass, is not exceeded. Of course, the more equipment you add, the less it's actual payload is. Remember once you add fuel, tyres, people and tools it more than likely reduces the amount of trailer weight you can legally tow with.
So if your Ford Ranger tow car GVM is 3200t and your GCM is 6000 even though your can tow a braked trailer up to 3500kg, if your at your 3200kg GVM on your tow car the most you can now tow is 2800kg. Not 3500kg.
It really opened my eyes as to how that all works. Driving on the M1 a lot like I do I'd reckon 2 out of 3 car trailers I see being towed would not meet with the above.........
Food for thought.
Spookypt
Hey this is not entirely correct not all f350's exceed the 4500kg weight, there are various models and it depends what you choose and the year of the build. Later model trucks weight more then the earlier versions due to the additional equipment that is now standard.
The latest and greatest f350 dual cab with dual rear wheels and a 8' tray does exceed 4500kg but if you get this vehicle with the 6 foot tray the chassis is shorter and the weight comes in just under the 4500kg. For the record both have the same GCM both have the same towing capacity.
An f350 with single rear axle is well below the 4500kg.
Another thing that comes into play with any of the f series trucks or any ute for that matter is the towing capacity and GCM change if your trailer is a fifth wheel configuration.
The towing capacity for the f series also varies dependant if it is 4x4 or just 2 wheel drive.
Because the f350 is the shorter f350 is so close to the 4500 (4380 from memory) you can actual choose to register it as a utility or a light truck.
Pays to do your homework though so you are well informed prior to parting with the loot.
