Old 09-24-2013, 01:01 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
It's probably a tapered needle and seat in the vacuum passage. Adjusting it changes the vacuum on the diaphragm.
That' true, but it must be a bleed in parallel with the diaphragm. The venturi signal strength then gets altered since it doesn't require a spring change to alter the opening rate.
Here you can see the bleed off:
Quick Fuel Adjustable Vacuum ADV Secondary Housing 63 1 | eBay
Gary
