Old 09-24-2013, 07:44 PM
cscobra cscobra is offline
Cobra Make, Engine: ERA #766, FE V8, Toploader
I put a NAPA Group 47 in mine. Mind the vent hose to the passenger footbox running above the battery when you install it.
I also used the Green Knob battery cut-off switch on the negative terminal (which is toward the engine, not the outer body). I disconnect the battery with this device for antitheft purposes and if I'm not going to be driving the car for more than a day.
