  #150 (permalink)
Old 09-28-2013, 09:55 PM
sevenohms sevenohms is offline
Cobra Make, Engine: Venom, BF XR8 260kw, 6 speed auto
Originally Posted by sideshow View Post
hi adam
make sure u get all the bits from the same car
and if u r going to go manual try find a complete manual car
I just finished an fg 6 cyl into an 88 patrol and it was a 6spd auto
but now it runs the patrol 5 spd manual
I spent 10 hours trying to reflash the ecu to become a manual because it would not rev past 2000 rpm because it was looking for the 6 spd auto and it wasn't there
well I finally figured it out and now revs to 6000
if u want to turn security off just find someone with tuning software and disable it
usually costs couple hundred bucks to turn it off then u just have to ire up the engine and ecu and it will start
if its an auto ecu and u need it manual then u need another piece of software and dongle
or take it to your ford dealer as they might do it if they feel like it
once u get it running u need a module for the tacho and fit some sensors to the engine for your gauges and your done
hey sevenohms u got yours running yet
does it bring up any error codes and does the dash bring up any warning lights
I know on the ve commodores if some of the factory modules are missing the dash brings up warnings and rings bells which is annoying
hi sideshow, i'm running the dash from the donor as the driver for the lights on the dash. it has lots of codes, but none that affect the engine, and with the tuning software I can turn off the ones that aren't required anymore.
