Old 10-01-2013, 01:47 PM
David Hodgson's Avatar
David Hodgson David Hodgson is offline
I'm with Gaz, check why your r/f is not working correctly and then sort the bias issue.
Have you had the calipers ovehauled? Pull them off and like Treeve says check everything, sliders for binding but also pull the pistons out and check for burs or rough surface on piston
SLIPRY
