Old 10-01-2013, 04:54 PM
Trevor W Trevor W is offline
Cobra Make, Engine: Harrison #102 Ford 5l Fuel Injected AU 2
Have Nissan R32 Rear Brakes with Green Stuff Pads No Proportioning, Gary
Calipers removed and checked by a Brake Coy,all ok. SLIPRY
Swapped pads roughed up with emery,discs new, haven't swapped rotors good thought Haven't measured over disk pads they look ok but will do so when I swap rotors, Treeve.
Next test I can think of to remove wheels lock back discs and check if there is diff, movement l/h to r/h slides. I have had one member advise his engineer wouldn't pass the car with Holden Front Calipers!!!!
Thanks all for your Thoughts
Trevor W
