Old 10-01-2013, 05:56 PM
Archrms's Avatar
Archrms Archrms is offline
Cobra Make, Engine: Superformance SPF#2572, 427 S/O 2X4
Originally Posted by undy View Post
Is the fuel dripping from your bowl vents??
If so, excessive fuel pressure (above 6 psi) is the mortal enemy of Holley's bowl float needle valves. They will lift and dump the further north of 6psi you get. Make sure your floats aren't set too high also.
It was dripping from the vents at first, then the boosters. I will try to check the fuel pressure tomorrow. What should a normal pressure be for a system with a mechanical pump?
Peace through superior firepower...or is it horsepower? Either way, more is always better!
