Old 10-01-2013, 05:01 PM
patrickt patrickt is offline
Originally Posted by Archrms View Post
It was dripping from the vents at first, then the boosters. I will try to check the fuel pressure tomorrow. What should a normal pressure be for a system with a mechanical pump?
Usually 5 to 7 psi. You can not rely on in-line liquid filled pressure gauges that are under there all the time (just in case you have one) -- they're just for show.
