Old 03-23-2002, 07:31 PM
rbray rbray is offline
Default Oil pressure sending unit problems
We finally got our fuel leak problems solved and we were going to fire the car up but we had a problem with the oil pressuge gauge. When I spun the oil pump with my drill ( in reverse ) I noticed that no oil pressure was indicated on the gauge. The accusump charged up fine and the oil pressure fuel cut off switch functhion as expected. We test the sending unit wire by putting a 1.5 volt battery on it and sure enough we got a reading on the OP gauge. The gauge and sending unit are Stewart Warner.
Any one have any suggestions on what I should do next?
Thanks for your help,
Roger
Roger
