Old 10-07-2013, 09:38 AM
kevins2's Avatar
kevins2 kevins2 is offline
Cobra Make, Engine: ERA #795 427 S/C completed Jan. '14 - '68 FE 427 side oiler
Originally Posted by strictlypersonl View Post
Use a trimmed engine intermediate plate to determine where to cut the bellhousing (as illustrated in the manual). That will put the bottom of the bellhousing approximately even with the chassis.
Hi Bob,
I did reference the drawing in the manual and also measured the 8" to center, as stated in the manual so think I'm good there.
Thanks for your help this morning, the drawing you sent helped us determine that the clutch fork pivot point was not correct and was indeed off roughly 1/4". The fix was to put the pivot bracket in a press and press some of the "L" shape out of it, which effectively moved the pivot point out the 1/4" needed. After that the fork and throwout bearing worked smoothly. The guy helping with this ran a weld along the bend in the bracket just in case bending it weakened it.
Thanks again.
Regards,
Kevin
"Anyone who drives faster than you is a maniac and anyone who drives slower than you is an idiot" - George Carlin
