Old 10-08-2013, 12:03 PM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
Change the linkage set up so the arms on the cross shaft on the fire wall point upwards instead of down-----and use the double carb return spring setup out there(one inside the other) to pull forward on the carb arm---it is best to have throttle return springs right at the carb primary shaft instead of the peddel---
