|    Not Ranked
 Thanks everyone.  I'm going to check with the local radiator shop first on the expansion tank.  It's only a pinhole right in the solder joint so I'm hoping it's an easy fix.  But, if he says its an iffy thing then I'll get a new one.  I took a chance buying it used but the forum member said he pressure tested it and thought it was good.   You never know for sure.
 Nick - have you had some of your tanks installed on an ERA with an FE?  I know ERA has specific heigth dimensions in their manuals for use in swapping the tank around for a Cobra.  Mine is right on their dimension and appears to have about 3/8 in clearance at best.
 Dan
