Old 10-10-2013, 04:06 PM
RET_COP's Avatar
RET_COP RET_COP is offline
Cobra Make, Engine: Fordstroker 408w custom solid roller-Craft ported Brodix 17*heads-CFM ported Vic Jr. intake-1 3/4 primaries- 575hp-TKO-600RR Liberty upgrade- -Moser 8.8 trutrac-McLeod Street Extreme--QA-1-Wilwood brakes, Classic Chambered 3" Cobrapacks, Avon's
The first number is the cold starting viscosity--the second is the viscosity HOT! Your Hot idle pressure is high. Some of it is due to the bearing clearances and the other is the 60W. You might loose maybe 10lbs at most by going to a 10w40 which would be a good move.
I use a 10w40 for the most part. I have been told my a reliable person that the slightly heaver oil ( as appose to the real light oil crowd at 20W) does a better job stabilizing the hydraulic lifter at high rpms without loosing the effect of oil cooling, by flowing through the bearings clearances. (part of this answer is from my own experiences)
Lou
Lou
