Thread: Ugly engine bay
  #21 (permalink)
Old 10-12-2013, 08:04 AM
chiefshocker's Avatar
chiefshocker chiefshocker is offline
Cobra Make, Engine: LAE 66 replica, 302
Originally Posted by RallySnake View Post
Ross,
Here's the idea that I came up with. Do you see any coil packs in this picture?
Well, I had an old 427 Surge tank that leaked like a sieve, so I cut the bottom out and made it into a coil pack cover. I had to modify the ends with some of the brass I cut from the bottom. I am using the same Ford EDIS coil packs as you, but turned upside down. I am using a Megajolt to control the ECU. One of these days I am going to clean the tank up and chrome it. Check it out from below and you can just make out the cable tie that holds it on:
I have to admit, it's one of my best ideas and you, my Cobra friend are welcome to it. Everyone else who uses it can send me $5.
The EDIS system makes the engine run SO much better than a distributor! It takes a long time to get used to the feeling that every cylinder is firing every time.
RS
Very Sneaky.. do you have a supercharger hidden somewhere too?
