Old 10-16-2013, 02:56 AM
Default Sounds like you are missing a ground
Jasper I don't have a wiring master in front of me but there should be a relay to the fuel pump The neg wire should go to a frame ground. The same applies for the injectors. Need to see if there is a pos or neg controlled from the ECU. Most are now ground controlled and have a battery or charging power to the injectors. There should be a relay for this power usage too. e-mail FAST and they will walk you through this problem. Rick L.
