Old 10-17-2013, 01:52 PM
ERA Chas ERA Chas is offline
If you have jack pads it's much simpler. Drill two holes in the plate the same diameter as the jack pad's studs (around 7/16") with the same spacing. Locate them on the plate so that the inboard edge of the plate just clears the radiator opening.
Install plate with the two jack pad nuts. A Greenlee punch makes a perfect, flat hole if you're particular.
Chas.
