Old 10-21-2013, 07:09 AM
Cobra #3170 Cobra #3170 is offline
Default Video
Nic,
I can't figure out what is going on with YOUTUBE, I can never post videos that can be seen for some reason, seems that when Google exerted their influence over youtube it quit being easy to use, first it was just a Google pass word, now you have to wade through all their face book wannabe BS to post a video. I uploaded it and checked make public but so far I am the only one to be able to view it. If I knew what I was doing wrong I would fix it but I have no clue. Maybe Ron could tell me what I need to do.
The new engine is really good now, it is responsive even as low as 1600 rpm even with that really low (numerical) first gear, it has a usable range of 20 mph to 90 mph with no shift required and can break traction with a nudge of the throttle at any time. I upped the caster this time around to 6.6 D. but have found that I have to reduce static camber to use that much caster. The car will be cornering perfectly at fairly high steering angles but if I have to add lock it understeers because (my theory) it has so much negative camber between static and caster that it gets up on the edge of the tire.
I am going to take 1 D. out of the front camber and see if that fixes it. If not I will go back to 5 D. caster. I am on street tires now and they have much stiffer side walls and need a little less static camber than Hoosiers.
Maybe this URL will work
http://youtu.be/_yV8NGkZEck
