Old 10-22-2013, 02:56 AM
blykins blykins is offline
I would steer clear of hydraulic throw out bearings.
As far as the other kit goes, you will need to figure out if you need something to work with an existing Mustang clutch pedal/quadrant/fork. That's what the other McLeod piece is designed to work with.
I have a complete setup that includes a powdercoated mounting bracket, slave cylinder, pushrod, etc., that works with a factory bellhousing and a TKO. $199. They are simple to set up and they work great. You would need a master cylinder to actuate it.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
