ecp:
I have a set of Edelbrock heads with the same size valves as your medium risers do. With $1,000 worth of porting they flowed 335 cfm and 240 cfm @ .650 lift.
Made 585 hp @ 6,000 rpm on pump gas with an Edelbrock dual plane intake and solid lifter (no roller) cam.
Jeff
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
