Old 10-31-2013, 02:08 PM
bobcowan's Avatar
bobcowan bobcowan is offline
The first thing to do is pull the balancer off and see what you've got.
After you remove the bolt, stick your finger in there and feel the end of the crank snout. The end of the crank snout should be below the level of the balancer hub. If it is not, then that is the reason for the failure.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
