Old 10-31-2013, 03:33 PM
ERA2076 ERA2076 is offline
Cobra Make, Engine: ERA - B2Motorsports Dart 331
Default Locking Rivet Nut
Is aluminum a worry - we like the wedges under the flange. We would look at counter boring so top was flush.
Wedges under the flange hold installed nuts tight, so they won't move when you apply torque to a screw. Install them in a drilled hole with an air-powered tool (required, see 92894A700 and 94675A111). Made from aluminum. Thread class is 2B.
Thread 1/4"-20
Drill Size 25/64"
Material Thickness 0.165"-0.260"
Body
Diameter 0.390"
Length 0.680"
Flange
Diameter 0.500"
Thickness 0.030"
Maximum Installed Length 0.380"
McMaster-Carr
