Old 11-01-2013, 07:52 AM
ERA Chas ERA Chas is offline
Originally Posted by Pliskin View Post
There are two ways to configure the exhaust system on a 9000 series coupe. Naturally the quad side pipes are integral to the look of a Daytona so they are present with either setup. First option is to have the side pipes as ornaments, basically, then they route the real exhaust system, pipes, mufflers and tailpipes to exit holes cut into the forward portion of the tucked under rear valance. This quiets the car considerably.
A word of advice.
A professional builder friend built a FF Daytona and powered it with a 650HP stroked FE. It's primarily for track and he immediately noticed that the motor hit an RPM wall about 5000 and determined the 'stock' Coupe quad small block sidepipes were too small. He fabricated basically a 427 sidepipe and found 6800 RPM again. Totally different on-track power.
And adding 40-50 pounds of undercar pipes won't help.
If appearance is all that matters, ignore...
Chas.
