Old 11-02-2013, 04:29 PM
patrickt patrickt is offline
Originally Posted by kevins2 View Post
Well, my first start went well and everything worked initially - I'll update my thread when I get a chance. Then, the cooling fans stopped working. I have the two front fans and the puller fan. What I've done so far:
Swapped the horn and fan relays, checked the connections to the dash override switch and touched the two leads on the thermoswitch together to see if the switch was bad.
All the fuses look good.
Any ideas?
Thanks,
Kevin
I would then suspect the plug that is on the driver's side, adjacent to the radiator, right at the fender well. Turn your fan override switch on and start wiggling that plug and the wires to it. See if that fires her up....
