  #21 (permalink)
Old 11-03-2013, 09:16 AM
DanEC's Avatar
DanEC DanEC is offline
Originally Posted by kevins2 View Post
Hi Dan,
Hope you find that problem. I assume you've started from the beginning and checked all the connections. Hopefully it something easily corrected.
Regards,
Kevin
Yes, there is a thread back there about 6 months ago that I started on the no-charge issue and I had all the usual suspects jump in to help out. Two voltage regulators, an alternator bench test and a bunch of multi-meter testing later I pretty much ended up with only one suggested option left - wire a resistor across the red warning light terminals to try and trigger the regulator into action. Like so much else, I just haven't gotten to it yet.
ERANJ is also having the same issue with his ERA unless he has managed to correct it the last couple weeks.
I'm glad you don't have that issue to deal with. You should be getting on the road in no time.
Dan
