11-03-2013, 02:26 PM
SC
Originally Posted by kevins2
Hi Dan,
Yes, I've been very fortunate that things have gone as smoothly as they have. I have one more issue to deal with. My right turn signal works with the steering wheel off but when I put the wheel on, it doesn't work. If I pull the steering wheel out just a bit (I do mean just a bit, probably 1/64") it starts working. I'm going to fiddle with the steering column adjustments and see if I can figure out what's going on. Other than that, I need a side view mirror and need to put the wipers on and I'm ready for inspection. I've put 36.4 miles on it so hopefully it will remain stable.
Regards,
Kevin
Kevin,
Pull your dash and watch how your wiring loom is run, check for a pinched wire or two. It is a rare occurrence on an ERA, but I have seen it happen. This would explain why your fuse blew, and why you have an issue with your turn signal.
Bill S.
