11-04-2013, 08:47 AM
Cobra Make, Engine: SPF#0760
FYI: Had another person with a similar problem. I think his charging system was pumping our +15.8 Volts on a regular basis. Seeing that the MSD box is usually hooked up directly to the hot side of the starter solenoid, the MSD was seeing high voltage and was probably overheating internally. Stalling out allowed the box to cool off, and the car restarted again. for a while, then died again. Just something to check into if you have this issue. Contact me off-line if you like regarding this. I'd like to collect some data on this from people having this problem - Seeing if they are experiencing high charging rates.
SPFWiringDiagrams@Comcast.net
