Old 11-04-2013, 11:55 AM
kevins2's Avatar
kevins2 kevins2 is online now
Cobra Make, Engine: ERA #795 427 S/C completed Jan. '14 - '68 FE 427 side oiler
Well, as I posted in #22 above, I fiddled with the steering column regarding the right turn signal problem. Actually, Bob at ERA gave me the specific advice to confirm I was on the right track. Since the signal works if I pull the steering wheel out just an almost immeasurable amount, I loosened the bracket that connects the upper steering column to the lower column and moved the shaft out just a bit to provide some clearance between the steering wheel and the turn signal mechansim. It is now working.
"Anyone who drives faster than you is a maniac and anyone who drives slower than you is an idiot" - George Carlin
