I'm using power valves front and rear in both JBL's with no problem and 1-1 linkage. Just have to find what works for you. I would try the 1-1 linkage first since it is the easiest then go from there. Jet extensions on the rear might be a good idea. I'll also add, I modified the PV inlet with a cover so when it opened under acceleration the inlet was always covered.
