Old 11-05-2013, 07:44 AM
patrickt patrickt is offline
Originally Posted by mptech View Post
Guys, don't forget that if your car has a flat, it's going to be about 2" - 3" closer to the ground sitting on the rim. So your jack is going to need to be less than 3" tall!
Yeah, but if you jack the back of the car up high enough, the front wheel comes off the ground too, and vice versa. Now if both tires on one side were flat, then you'd have a real problem -- whether you had a spare or not. Jack it up from the differential, I suppose.... I do carry two big cans of Fix o' Flat and a cheap little 12v air compressor (that has blown up more basketballs than it has tires).
