  #38 (permalink)
Old 11-08-2013, 05:27 AM
patrickt patrickt is offline
Originally Posted by kevins2 View Post
I wrapped the bad fuse in a small cloth and used a pair of pliars to break the fuse open without putting any stress on the ends. One of the ends was not attached (the other end is very firmly attached and can't be pulled out by hand). The end of the filiment shows no sign of burning. In fact, it has a shiny coat of solder. So - cold solder joint.
Bottom line is you can't judge a fuse by its appearance
Break open three "known good fuses" and then compare whether or not they appear to have the same flaw... if it is a flaw at all.
