Old 11-11-2013, 05:52 PM
lippy lippy is offline
Did you roll the carpet around the front of the transmission tunnel per the instructions? If so, any problems getting the tunnel to fit all the way down over the footbox sides with the extra material?
Dan, that was a b*tch, but I did it. All of the carpet went in very easily, except the curved portion behind the seats on the front of the rear footwells (I had to do one side over and it still isn't absolutely perfect, but it is good), and the front of the tunnel. On the tunnel, there were too many compound curves so I had to make one strategic cut and it turned out nice. Make sure you follow their directions exactly and work from the top down, and let the glue on the top portion dry before doing the sides.
