Old 11-11-2013, 09:01 PM
ERA Chas ERA Chas is offline
Originally Posted by STL Mark View Post
2) Do a bit more research about Webber, and EFI set-ups. You may find that the "Look" you seek comes with a hefty price tag. Prepare for money well north of $7000 - just sayin. I'd wager that you'll probably have to get a different cam in that beast. Most of those set-ups require a specific cam grind, and I doubt the current monster cam you undoubtedly have will fit the bill.
I alluded to this very point in post #8-that the planned induction change is very dependent on the engines ability to use it. Since you don't know any specs, you would need to change out parts like cam and heads to be more compatible with the chosen induction. I know the cost doesn't bother you, but you may wind-up with an undriveable lump because unlike Mark, I suspect you have low-performance parts.
Even a stock iron 460 with 450 HP would easily do what you accomplish the way you use the car.
Mark makes a good point; tearing into your engine (by a reputable builder) just to identify parts is money better spent before a comprehensive induction change-over.
Chas.
