Old 11-12-2013, 05:43 PM
BOBOCobra's Avatar
BOBOCobra BOBOCobra is offline
Cobra Make, Engine: Kellison West Coast
The braided hose goes to a fitting I mounted under the air cleaner base, a brass fitting with 5/8" hose connection, $5 at home depot. the chrome air breather was $20 at O-Reiley. On the opposite valve cover is the standard PCV valve with a hose to the front of my carb vacuum port. For mine that is the PCV port. Yours may be different but you have one or need a carb spacer with a port. You will NOT get through without this set up. If you are lost take to a local mechanic that works on rods and they will know exactly what you need.
