Old 11-18-2013, 07:35 AM
bill37341 bill37341 is offline
Cobra Make, Engine: Scratch-built 427 MR
750 hp-You might try the solution I used. Simply reverse the lower wishbones left to right. This puts the original bracket for the Jag radius rod facing to the rear. (See my post to Tramsey on 6-11-12). A 3/4 inch heim joint with a 5/8 high-misalignment spacer will let you use the original 5/8 inch bolt to attach to the original location of the Jag radius rod. The spacer is necessary to let the rear-facing radius rod to swing far enough to the center of the car to line up with the center pivot point of the wishbone. Wish I knew how to post pix. Bill.
