  #72 (permalink)
Old 11-20-2013, 02:26 AM
PANAVIA's Avatar
PANAVIA PANAVIA is offline
There are ways of making the car a bit safer to drive for first time cobra personnel
1. raise idle up to 900 RPM to ease clutch engagement
2. add a stronger throttle return spring as to reduce pedal itchiness
3. advance the timing a tick to reduce power and make it easier to clutch
4. set rev limiter to 3000RPM ( if so equipped )
5. rig a kill switch from passenger area to drop power out of the ignition.
you can then take them to a controlled area and start driving lessons in the cobra.
