I have Trick Flow 205cc CNC'd heads, domed pistons (static 11.5:1 compression), Lunati hyd roller cam (.571/.587 lift, 112LSA). The TF heads use the R gasket, but i plan to port match the Weber manifold to the 1262 gasket..
Do you think I'll be making close to that number? Would be great if I did. Thanks
