11-26-2013, 08:49 AM
Junior Member
CA
Cobra Make, Engine: 1980 Arntz 427W, Webers, TKO600, Jag IRS
You should check the Cam degrees as set to the crank. I had a similar problem on a different stile motor and changed the cam 3 degrees to the correct spec. and can now rev to 6500. Use a degree wheel not the dots on the gears.
Tom
