Old 11-30-2013, 05:35 AM
mdross1's Avatar
mdross1 mdross1 is offline
Since this article started have done a lot of leg work on the roller tappet issue of failure.Have found that it is isolated most people do not have issues other than an occasional part failure. With that decided to eliminate as much chance of failure as possible that being the needle bearing rollers. The SB2 motor recently finished went with Isky EZ-Roll lifters.This engine will run 680lb open lift.
