Old 12-01-2013, 03:35 PM
dhs.buckley's Avatar
dhs.buckley dhs.buckley is offline
Cobra Make, Engine: Python ford 302 ho, 4 speed toploader, jag irs 3.54
Originally Posted by Rich A View Post
If your fuel pressure, fuel supply and fuel ratio is all okay you dont need another pump. It won't make you any more HP.
found out with the 465 holley single fuel line, that the rear fuel bowl is empty after about 5 seconds of wide open throttle so in this case the 70 litre per hour pump will not keep up with 465 with vac secondaries,so no chance with the 670 holley with twin fuel lines.
