Old 12-01-2013, 04:57 PM
Towmaster's Avatar
Towmaster Towmaster is offline
Originally Posted by dhs.buckley View Post
found out with the 465 holley single fuel line, that the rear fuel bowl is empty after about 5 seconds of wide open throttle so in this case the 70 litre per hour pump will not keep up with 465 with vac secondaries,so no chance with the 670 holley with twin fuel lines.
Yep agreed, you shouldn't need two lines from the pump in the boot to the engine, just one line, about half inch should be fine. Does it have the standard camshaft in it? IF so put in a bigger cam.....
