Old 12-01-2013, 05:30 PM
Andrew429's Avatar
Andrew429 Andrew429 is offline
Cobra Make, Engine: G-Force MkII, Ford 429, Tremec TKO, Jag Suspension, Sequential LPG Injection, On The Road.
Hi tpatodd,
I have also had a problem with the brakes not fully releasing.
As Cashburn described check for pedal box binding, but more importantly, do it after a run in heavy traffic and you have everything heat soaked.
The pedal box I had suffered from slight binding as things got warm causing both the clutch and the brake pedal to bind slightly. The movement when cold was unaffected. A return spring on the pedal is also a good idea.
Andrew
