Old 12-03-2013, 10:30 PM
bobcowan's Avatar
bobcowan bobcowan is offline
Originally Posted by CJ428CJ View Post
He mentioned Russels but I suspect he was thinking about the Earls sandwich type oil t-stat.
Chris
Yes, Chris, you're right. It's an Earls part. I used that for a while. It is a quality part, not cheap cast aluminum.
I also drilled and tapped mine for the temp sender, so I could see what temp the oil is as it's being fed to the engine.
Originally Posted by Double Venom View Post
put an EARLS remote filter locator after the thermostat, do you think it/they will fit?
If it doesn't fit, put the thermostat between the oil filter and the remote mount.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
