Old 12-04-2013, 09:56 AM
CHANMADD's Avatar
CHANMADD CHANMADD is offline
One other thing.........did you say if you are using a stock pickup or an aftermarket pickup.......I still think half inch at the pickup is too big and will cause a vortex resulting in a drop .......also I have seen a lot of problems with the aftermarket so called better pickups........trust me the factory spent a lot of money coming up with the correct design.......But again , why not pull the pump and take it apart and give it qn internal "flow" job..........there is a lot that can be done inside the pump.......and 1/2 inch is too far....
