Old 12-08-2013, 08:54 PM
WardL's Avatar
WardL WardL is offline
Cobra Make, Engine: SPF #2608, Roush 427SR T-W
My SPF tank is vented to the atmosphere right under the gas cap. There is an overflow tube to direct excess fuel to the ground. I believe most SPFs were initially set up this way. If your tank is a sealed system, it is likely a custom setup. If your system is not intended to be closed system, then your overflow tube is definitely plugged and should be replaced or unplugged.
